Electric Utility Network - Switch Center
1129
09-28-2022 11:49 AM
CamMiller17
I am trying to create a switch center but can't seem to find the particular device/assembly to create this. I have a line running from the BUS location to a switch center and then several switches running within that switch center to other transformers. I was wondering if anyone can help myself out with that.
I am running ArcGIS Pro 3.0 and single user utility network creation.
JohnBendix
I don't know exactly what you mean by switch center? But if your talking about a pad mounted switch we have various assemblies built for our Electric Distribution most of them contain 3 lines that make up the buss.
Then depending on the switch configuration we typically have 4 switches connected to the bus then a set of elbows for each switch that are connected to there switch. If that makes sense. I attached a sample assembly for you to look at.
John.
CamMiller17
I am trying to use the terminology from our electricians. The "switch center" (which is at the top of the image attached) runs from our transformer. It contains switches running to different transformers and switches.
