Using UN of Auburn Lesson and translate it
1066
09-27-2022 03:44 AM
gpgisandsky
I would like translate the UN of Auburn used in
Get started with the ArcGIS Utility Network | Learn ArcGIS
so I need asset package, configuration table and rename table. I'm using untools 2.9.3 on ArcGIS Pro 2.9.4
I tried the following step:
1) create an asset package using the tools "Export Asset Package" so I created GettingtoKnow_asset.gdb
2) call tool "create asset package configuration table" on GettingtoKnow_asset.gdb
The second step did't work and the following error appear:
Create Asset Package Configuration Table
Parameters
Asset Package C:\ArcGIS\lesson\GettingtoKnow_ita2\p20\exportAssetTest\GettingtoKnow_asset.gdb
Configuration Fields
Output Package
Messages
Start Time: martedì 27 settembre 2022 12:05:45
ArcGIS Pro 2.9.4.32739
untools 2.9.3
Executing from ArcGIS Pro, 2 map(s), activeMap = True
Parallel processing enabled: 12
The asset package has the following errors (22/22):
Item Field OID Value Message Level
0 B_AssociationRole asset_type 7 Structure/StructureEdgeObject/Duct/DuctBank Asset Type doesn't exist in this feature class / asset group error
1 B_AssociationRole asset_type 16 Structure/StructureJunction/Pole/MinPole Asset Type doesn't exist in this feature class / asset group error
2 B_AssociationRole asset_type 17 Structure/StructureJunction/Pole/MyTestContainer Asset Type doesn't exist in this feature class / asset group error
3 B_AssociationRole view_scale 1 0.0 Scale must be greater than 0 error
4 B_AssociationRole view_scale 2 0.0 Scale must be greater than 0 error
5 B_AssociationRole view_scale 3 0.0 Scale must be greater than 0 error
6 B_AssociationRole view_scale 11 0.0 Scale must be greater than 0 error
7 B_AssociationRole view_scale 32 0.0 Scale must be greater than 0 error
8 B_AssociationRole view_scale 33 0.0 Scale must be greater than 0 error
9 B_AssociationRole view_scale 34 0.0 Scale must be greater than 0 error
10 B_AssociationRole view_scale 35 0.0 Scale must be greater than 0 error
11 B_AssociationRole view_scale 36 0.0 Scale must be greater than 0 error
12 B_AssociationRole view_scale 37 0.0 Scale must be greater than 0 error
13 B_AssociationRole view_scale 38 0.0 Scale must be greater than 0 error
14 B_AssociationRole view_scale 39 0.0 Scale must be greater than 0 error
15 B_AssociationRole view_scale 40 0.0 Scale must be greater than 0 error
16 B_AssociationRole view_scale 42 0.0 Scale must be greater than 0 error
17 B_AssociationRole view_scale 43 0.0 Scale must be greater than 0 error
18 B_AssociationRole view_scale 52 0.0 Scale must be greater than 0 error
19 B_AssociationRole view_scale 53 0.0 Scale must be greater than 0 error
20 B_AssociationRole view_scale 54 0.0 Scale must be greater than 0 error
21 B_AssociationRole view_scale 55 0.0 Scale must be greater than 0 error
Failed to execute (CreateConfigurationTable).
Failed at martedì 27 settembre 2022 12:05:49 (Elapsed Time: 3,26 seconds)
MikeMillerGIS
Esri Frequent Contributor
I reviewed the Utility Network in that lesson.  It is in an odd/corrupt state.  The Duct Asset Group has Asset Types defined in the Utility Network that do not exist in the AssetType domain assigned to that asset group.  I did not review the others, but assume they are in a similar state.
If you need an electric model, I suggest you look at the https://doc.arcgis.com/en/arcgis-solutions/latest/reference/introduction-to-electric-utility-network...
gpgisandsky
Hi Mike, I would like use Auburn data model because "Electric Utility Network Foundation" is more complex. May I have a GettingtoKnow.gdb with uncorrupt state so I can work with export asset and work with D_Configuration and D_Rename table?
MikeMillerGIS
Attached
gpgisandsky
Thanks, you're very kind.
