We are using Utility Network and trying to create a usable map in Experience Builder. When the user clicks on an item in Experience Builder to see the details, only the domain coded value displays. How can we get the domain description to display?
Hi All,
I've just checked in Exb and it displays the code description.
Subtype description instead of the coded value in popup has been enhanced (Fixed by API). This feature was already released in November 2024 and will be released in the upcoming Portal 11.5(at the end of May).
Ke
When you say "already released in November 2024", does that mean it is in a patch?
It's not a patch. It was fixed in in November 2024.
