Configuring Subnetwork with no Spatial Object
7920
17
01-05-2023 02:57 AM
chiaramallegni_84
Hi everyone,
I'm working with ESRI Solution Communications Utility Network Foundation which massively uses no spatial Objects, for example Tier communication Circuits and switch are composed only of no Spatial Objects.
I need to generate the feature in the FC Communication Subnetline deriving from the path of the Strands (Edge Object) contained in the Cable (Line), starting from subnetwork Controller Connector and Switch which are No Spatial Object belonging to the Tier Communication Circuit and Switch.
It's possible to do it?
How can I configure the model to get this result when I call GP the update subnetwork?
Thank's a lot!
Chiara
MikeMillerGIS
Esri Frequent Contributor
This tool does not require changing the subnetwork definition.  It will use a trace configuration to override the subnetwork definition.  This is identified by tags.
chiaramallegni_84
Hi Mike,
I tried to follow your suggestion. Without changing subnetwork definition the result is still a null polyline (lenght = 0).
We also noticed that the FC output has no M, which is useful for LRS. Is there a way to switch output and add it?
MikeMillerGIS
Please export your trace configuration to csv so I can see what is going on.  Also, share a screen shot or the python call for how you ran the tool.  I am suspecting that it is not finding the trace config correctly
chiaramallegni_84
Hi Mike,
First of all an important information we are working with release 2.9.4.
following your request:
Trace configuration:
subnetwork_aggregator:
Thanks a lot!
MikeMillerGIS
You need to add another tag, SubnetworkOverride
chiaramallegni_84
Hi Mike,
I'm probably doing something wrong but even with the SubnetworkOverride tag the result is the same: null geometry. (These are some more tests I did: SubnetworkOverride set as first tag, SubnetworkOverride set as second tag, SubnetworkOverride set as single tag).
MikeMillerGIS
Your trace type is downstream, the will only load trace types of Subnetwork.  Do you want to use a downstream trace?  I can remove that restriction.
Also, turn on debugging, this will provide more info
open the toolbox and load the Subnetwork tool to the GP Pane
Open a python command prompt and type the following
import udms
udms.logger.setLevel('DEBUG')
chiaramallegni_84
Thanks, with sunbnetwork trace solve it works!
