Hi everyone,
I'm working with ESRI Solution Communications Utility Network Foundation which massively uses no spatial Objects, for example Tier communication Circuits and switch are composed only of no Spatial Objects.
I need to generate the feature in the FC Communication Subnetline deriving from the path of the Strands (Edge Object) contained in the Cable (Line), starting from subnetwork Controller Connector and Switch which are No Spatial Object belonging to the Tier Communication Circuit and Switch.
It's possible to do it?
How can I configure the model to get this result when I call GP the update subnetwork?
Thank's a lot!
Chiara
This tool does not require changing the subnetwork definition. It will use a trace configuration to override the subnetwork definition. This is identified by tags.
Hi Mike,
I tried to follow your suggestion. Without changing subnetwork definition the result is still a null polyline (lenght = 0).
We also noticed that the FC output has no M, which is useful for LRS. Is there a way to switch output and add it?
Please export your trace configuration to csv so I can see what is going on. Also, share a screen shot or the python call for how you ran the tool. I am suspecting that it is not finding the trace config correctly
You need to add another tag, SubnetworkOverride
Hi Mike,
I'm probably doing something wrong but even with the SubnetworkOverride tag the result is the same: null geometry. (These are some more tests I did: SubnetworkOverride set as first tag, SubnetworkOverride set as second tag, SubnetworkOverride set as single tag).
Your trace type is downstream, the will only load trace types of Subnetwork. Do you want to use a downstream trace? I can remove that restriction.
Also, turn on debugging, this will provide more info
open the toolbox and load the Subnetwork tool to the GP Pane
Open a python command prompt and type the following
import udms
udms.logger.setLevel('DEBUG')
Thanks, with sunbnetwork trace solve it works!
