best pratice for project UN and preserve the data
1614
8
03-14-2023 01:11 AM
gpgisandsky
Dear all,
I have a UN (v6 in a fgdb - A) in a spatial reference and I want project it in another one and preserve the data within.
I tried two way:
- project the dataset which contain UN to another dataset with the new spatial reference using project tool. In this case the project works fine but the new dataset lose the UN.
- export my UN in a asset package (untools v3.1) then use change asset package spatial reference. In this case the new asset package lose the data.
How I can preserve my data?
Thank you
Giuseppe P.
MikeMillerGIS
Esri Frequent Contributor
That error is correct, enable of the network topology failed.  The asset package succeeded.
MikeMillerGIS
If you create a new Utility Network, in the new spatial reference, then apply the asset package to that UN, it should project the data during the append on the fly.
gpgisandsky
Maybe theoretically yes but in my feature I used forward slash character in a domain description (is it forbidden?) so when:
- apply the asset package with forward slash in a domain description the following error appear:
Apply Asset Package
Parameters
Asset Package C:\Arcgis\Elettrico\0_dati_input\ElettricoUNv6_newasstype_asspack.gdb
Domain Networks to apply Structure;Pipeline
Input Utility Network C:\Arcgis\Elettrico\0_dati_input\03_multidominio_import2asset.gdb\xxxxxxx\Hydroelectric
Load data INCLUDE_DATA
Calculate Spatial Index and Analyze ANALYZE
Output Utility Network
Configurations to apply
Rename using
Post Process POST_PROCESS
Messages
Start Time: Tuesday, March 14, 2023 9:48:14 AM
ArcGIS Pro 3.1.41833
untools 3.1.0
Executing from ArcGIS Pro, 1 map(s), activeMap = True
Parallel processing enabled: 3
Asset Package schema version: 3.1
The asset package has the following errors (88/88):
Item Field OID Value Message Level
xxxxxxxxxxxxxxxxxxx
86 None None NaN Asset_Type_Pipeline_Junction_Nodi (1:GIUNTO DI TRANSIZIONE ACCIAIO/PE) '/' should not be used in AssetType names warning
87 None None NaN Asset_Type_Pipeline_Junction_Nodi (2:GIUNTO DI TRANSIZIONE PVC/PEAD) '/' should not be used in AssetType names warning
Failed to execute (AssetPackageToUtilityNetwork).
Failed at Tuesday, March 14, 2023 9:48:51 AM (Elapsed Time: 37.12 seconds)
- if I try to use D_Rename table in order to remove character the following error appear:
Apply Asset Package
Parameters
Asset Package C:\Arcgis\Elettrico\0_dati_input\Asset_Package_Retexo_v6.gdb
Input Utility Network C:\Arcgis\Elettrico\0_dati_input\03_multidominio_import2asset.gdb\xxxxxxxxxx\Hydroelectric
Rename using renameslash
Messages
Start Time: Tuesday, March 14, 2023 1:40:47 PM
untools 3.1.0
A python error occurred.
EXCEPTION
File "C:\Users\Administrator\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-electric\lib\site-packages\untools\common\wrappers.py", line 159, in wrapper
f = func(*args, **kwargs)
File "C:\Users\Administrator\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-electric\lib\site-packages\untools\gptools\tools.py", line 609, in run
ap = ap_constructor(
File "C:\Users\Administrator\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-electric\lib\site-packages\untools\gptools\tools.py", line 53, in ap_constructor
ap = AssetPackage(
File "C:\Users\Administrator\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-electric\lib\site-packages\untools\utility_network\ap.py", line 98, in __init__
EvaluateRename(self, rename_field).main()
File "C:\Users\Administrator\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-electric\lib\site-packages\untools\utility_network\rename.py", line 718, in main
self.fix_xml()
File "C:\Users\Administrator\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-electric\lib\site-packages\untools\utility_network\rename.py", line 713, in fix_xml
self.modify_table_alias(lookup.get(AssetPackageRename.TABLE_ALIAS.name))
File "C:\Users\Administrator\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-electric\lib\site-packages\untools\utility_network\rename.py", line 492, in modify_table_alias
self._modify_element(table, "AliasName", lookup.get(table.findtext("Name"), {}))
File "C:\Users\Administrator\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-electric\lib\site-packages\untools\utility_network\rename.py", line 293, in _modify_element
prop.text = mapping.get(prop.text, prop.text)
AttributeError: 'NoneType' object has no attribute 'text'
Failed at Tuesday, March 14, 2023 1:41:31 PM (Elapsed Time: 43.65 seconds)
MikeMillerGIS
Can we get a schema only Asset Package?  Would help us hunt this down.
gpgisandsky
Hi Mike I sent the fgdb to your private box.
thank you for your support.
MikeMillerGIS
1:  For the first issue, look in those 88 messages, we need the one that is an error.  You only posted the warnings.  Can you find the Error or send the entire list?
2:  In your rename table, run a select by Attribute -  property_type = 'Table Alias'.  The last one is a table called Test, that exist as a FeatureDataset and FeatureClass.  There is a bug in the code when a table and FD have the same name.  Either remove this entry or rename your table or Feature dataset
gpgisandsky
I'm sorry for point 1 maybe it was an old fgdb where i tried to re-create it manipulating the xml in order to remove "/" character.
About the point 2 in the asset package i manually renamed "test" feature dataset in "dataset_te" and I didn't change the D_Rename table because "test" is about table alias.
when I apply the asset package I got e new message...:
Apply Asset Package
Parameters
Asset Package C:\Arcgis\Elettrico\0_dati_input\Asset_Package_xxx_v6.gdb
Input Utility Network C:\Arcgis\Elettrico\0_dati_input\03_multidominio_import2asset.gdb\xxxx\Hydroelectric
Configurations to apply renslash
Messages
Start Time: Tuesday, March 14, 2023 4:11:46 PM
untools 3.1.0
Staging directory -- C:\Arcgis\Elettrico\0_dati_input\AP_Workspace3
The asset package has the following warnings (2/2):
0 None None None Asset_Type_Pipeline_Junction_Nodi (1:GIUNTO DI TRANSIZIONE ACCIAIO/PE) '/' should not be used in AssetType names warning
1 None None None Asset_Type_Pipeline_Junction_Nodi (2:GIUNTO DI TRANSIZIONE PVC/PEAD) '/' should not be used in AssetType names warning
Start Time: Tuesday, March 14, 2023 4:12:53 PM
ERROR 160344: The number of errors generated during the topology analysis exceeds the specified threshold.
Failed to execute (EnableNetworkTopology).
Failed at Tuesday, March 14, 2023 4:13:00 PM (Elapsed Time: 6.64 seconds)
Failed at Tuesday, March 14, 2023 4:14:55 PM (Elapsed Time: 3 minutes 8 seconds)
MikeMillerGIS
gpgisandsky
Thank you Mike. It's works fine.
