ArcGIS Pro Standard Concurrent for Utility Network Desktop use
1402
04-22-2025 03:31 AM
Rohanrajan
I have an ArcGIS Pro Standard License v3.3.5 served through License Manager as a Concurrent License. I am currently configuring UN in just the File Geodatabase. I am able to stage UN. But Apply Asset Package tool throws error (with both EUNF essential Asset Package and my own asset package.)
"ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds."
I tried installing and reinstalling the untools package too.
1. Is there any other specific requirement other than a Standard License to work with UN in a FGDB.
Any advice on this is much appreciated
Thanks
CashEddy
@Rohanrajan
The UN will require an ArcGIS Advanced Editing license that you are using when logged into ArcGIS Pro.
Hope this helps!
-Cash
DanPatterson
MVP Esteemed Contributor
There are qualifications specified in the faq section which you will have to look at in regards to your situation
Frequently asked questions—ArcGIS Pro | Documentation
... sort of retired...
Rohanrajan
The FAQ had mentioned about Advanced Editing User Type requirement for the Enterprise Deployment. Is it required for a Single User Deployment too? Because a concurrent license does not require a portal account or named user to be signed in right!?
CashEddy
@Rohanrajan
Hope this helps!
-Cash
