ArcGIS Pro 2.6: Connected tracing ends up with “No valid starting locations found”,
985
5
08-07-2020 01:50 AM
JamalNUMAN
Legendary Contributor
Despite the fact that a starting point is added correctly on an edge that participate in a utility network, the Connected tracing ends up with “No valid starting locations found”.
What could be the issue here?
The data is attached
Jamal Numan
RomanSmolinski
I have this same problem. Did you find the solution?
Roman.
JamalNUMAN
Unfortunately, it appears that we have very small community for this and this is why most of our issues are left with no answers
Jamal Numan
MikeMillerGIS
Esri Frequent Contributor
Jamal,
   I took a look at the data.  I was able to repo the issue.  Once I disabled Topo and Enabled it again, the trace worked.  So the data was not in the network index.  I am not sure how this happened.  What was the ordered of events?  Did you sketch in the data or did you append it?  Was the data sketched first and then the rules added?
MelissaJarman
Thanks Jamal - Getting more information about how the data got in this state would help us pin point the issue.
You also cannot generate network diagrams with the network features in the current state. After you make a slight edit to the feature to generate a dirty area, validate works, and then a connected trace can be completed. Interested in hearing more about the order of operations to see if this can be replicated.
JamalNUMAN
Hi Mike,
Right. disabling\enabling the network topology resolves the issue despite the fact that the popped-up error has nothing to do with the solution
Hi Melissa,
Sure. I edit, save, validate and trace.
The popped-up message needs to be enhanced to better indicate what the issue is. What do you think?
Jamal Numan
