The purpose of this document is to provide a step-by-step guide on how to create SVG files for existing multi-layered symbology styles. SVG symbology can improve performance in services, and is recommended for publishing of Utility Network Model services. This workflow requires ArcGIS Pro and Adobe Illustrator
- Open ArcGIS Pro and open a new map and delete out the base layers
- Create a new point feature class in Catalog, and import it to the map
- this is required for visualising and exporting the symbols in future steps - no attribution is required
- Create a single point in the map window, and save edits
- Go to the Appearance tab > Symbology > Single Symbol
- The Symbology pane will open
- In the symbology pane, next to Symbol, click on the symbol icon
- Navigate to the symbol in the library that you want to convert to SVG and select it.
- the point in your map window will update with the selected symbol style
- Create a new layout window (Insert > New Layout > A4).
- NOTE: The size of the layout window is unimportant
- In the Layout window, go to Insert > Map Frame and select the map window with your point in it.
- Click and drag an area within the layout window for the map frame
- Click Share > Layout
- Change the ‘save as type’ to SVG (.svg), keep the resolution at 96 DPI, and set Image Quality to Best
- Open Adobe Illustrator
- Open windows explorer and navigate to the saved SVG file
- Click and drag the SVG file into the adobe illustrator frame
- Accept any warnings
- You will see the extents of the map frame in Adobe, with the one symbol within the frame
- Click the ‘direct selection’ tool from the tool bar > click on the white mapframe > press delete on your keyboard. This will get rid of the background layer. NOTE: The page will still appear the same as before
- Ensure the direct selection tool is still active, and click and drag a box around the icon. ensure there are no background layers select (selections are indicated by highlighting the vertices in blue - screenshot below)
- Press Ctrl+C on your keyboard to copy
- Go to File> New
- In the New Document window, go to Web > Minimum and click Create
- In the new blank window, click Ctrl+V to paste the icon into the new window.
- NOTE: Because this is a web style, the white background is effectively non-existent at the export stage
- Go to File > Export > Export As and in the export window ensure SVG is selected as the export type. Click Export
- A new window pane will appear for SVG Options. Ensure the following settings are set, and click OK
- Styling: Presentation Attributes
- Font: SVG
- Images: Preserve
- Object IDs: Minimal
- Go back to ArcGIS Pro, and select your existing Map window
- In the symbol library select a simple symbol style (simple circle) and go to the Properties tab
- Under Appearance, click the File button
- Navigate to the SVG file youve published from Adobe Illustrator and click OK
- The SVG symbology file is imported into the symbology pane
- Click on the icon next to ‘Element’ to see the drop down of every element within the SVG, and the ability to edit each element individually
- Click Apply for the symbol to appear in the map window
