Viewing/Editing Attachments from the Inbox
1340
05-22-2024 11:24 AM
MT_JenAmes
I have multiple surveys where end users are accessing and editing through the inbox, and we have come across a few questions related to attachments. All of the below situations are when accessing the form through the Inbox, not when initially submitting the form.
Situation 1: Attachments (with a file type question) that were added during initial submission are not visible at all when viewing from the Inbox. It just has the question title, and then immediately followed by the next question title. The attachments aren't visible at all, on top of not being able to add new attachments.
Situation 2: Attachments (with an image type question) that were added during a previous submission can not  be deleted. Is this by design? Is there any way in Survey123 to delete a previously attached photo? Or if the wrong photo was attached, is there a way to replace it, rather than delete it?
Situation 3: Occasionally on a form with attachments (originally published as a file type question, republished as an image type question) the existing attachments aren't showing up. The attachments are still there, as confirmed by viewing in Field Maps, Map Viewer, and/or the Survey123 web version data page, but the question in the form does not show any of the existing images, it just has the button to add new images. This is not a consistent issue, many records do show all of the previously attached images, but some of the existing records do not show existing attached images at the attachments question.
I can share xlsxs if it would be helpful, but these 3 scenarios are occurring across multiple different surveys.
ToddW_stl
@MT_JenAmes - if you're still working with this, I posted a potential workaround for scenario 1 here.
Unsure about scenario 2, but that may be by design.  Potential workaround here.
Scenario 3 - if the question type changed, I would expect "file" types to be returned by an "image" type question for surveys that have already been submitted.  You may have to look in the database and examine or update the attachment keyword or other related attribution.
abureaux
MVP Frequent Contributor
Did you set a query parameter?
MT_JenAmes
I have not. Is that required so attachments are always visible? Would this only be on attachment questions, or would it have to be set elsewhere in the xlsx?
ToddW_stl
MT_JenAmes
I made some changes to the forms this was happening on, and haven't heard anything from my end users about the problem in months, so it might still be an issue that they've just accepted, it might have resolved with my changes or with time.
Your workaround for scenario 1 is definitely something I will look into! That is an interesting proposal that could be really useful.
I agree with you that scenario 2 is probably by design, was just hoping there would be a way to do it that end users wouldn't have to reach out to me every time they need an attachment deleted.
In regards to scenario 3, I had just written it off as a fluke. But I will look into that.
Thank you!!
