I'm having trouble with a Survey123 web form where a "select_multiple" question uses an external choice list and a choice filter. The list isn't appearing in the web form, though it works fine in Survey123 Connect.
Thanks for any advice!
No limitations. There may be wrong with the CSV. Any chance you can share it here?
Here is an external select_multiple I did as a test. This CSV as ~1300 choices and it displays fine in web.
(name list, so names censored. I know this isn't a lot to go off of, but trust me when I say it's a working External Select in web!)
The browser is less forgiving than Connect and the Field App, so if it is working in Connect and not the browser you likely have a slight syntax error somewhere.
