Using an external choice list with a choice filter in the web form on a select multiple - list not populating
82
Thursday
MeganEngel
Occasional Contributor II
I'm having trouble with a Survey123 web form where a "select_multiple" question uses an external choice list and a choice filter. The list isn't appearing in the web form, though it works fine in Survey123 Connect.
What I've Tried:
  • XLSForm Check: All references and filter logic seem correct.
  • Browser Testing: The issue persists across different browsers
  • Mobile App: Works as expected
  • Connect Test: The list appears without issues in Survey123 Connect.
Questions:
  1. Is there a known issue with this setup in web forms?
  2. Any workarounds or solutions to make the list appear correctly?
Thanks for any advice!
abureaux
MVP Frequent Contributor
No limitations.  There may be wrong with the CSV. Any chance you can share it here?
Here is an external select_multiple I did as a test. This CSV as ~1300 choices and it displays fine in web.
(name list, so names censored. I know this isn't a lot to go off of, but trust me when I say it's a working External Select in web!)
JenniferAcunto
The browser is less forgiving than Connect and the Field App, so if it is working in Connect and not the browser you likely have a slight syntax error somewhere.
- Jen
