URL Scheme to open a survey response in Field App
703
02-27-2020 12:47 PM
AndrewBowne
I am trying to open an existing response in the field app by passing it the objectId as a URL parameter however it does not seem to be working.  I can't find anywhere in the documentation that says it's possible.  I can open the app (with a specified survey) and create a new response.  However, I'd like to be able to pull in an existing survey response for editing.  This is easy enough to do with the web form however I can't get it working with the native app.
Andrew
JamesTedrick
Esri Esteemed Contributor
Hi Andrew,
Opening an existing record is not yet supported in the field app.
GaryBowles1
James,
I am trying to send the url to a specific survey via GeoEvent Server notification. I have 2 questions, is this even possible and is the format below correct?
arcgis-survey123://?itemID=ba1fe0b79c014e6d864022ff8bccd783&field:ft_field_ticket_calc=${ft_field_ticket_calc}
--gary
