How do I pull characters out of a string in Survey123?
6265
05-06-2020 02:52 PM
AaronFisher3
Is there a way in Survey123 to pull characters out of a string.  For example, the answer to question 1 is "ABC123".  I want another question to automatically pull "ABC" from that text.
A calculation like LEFT(${Question1},3) is what I was hoping for, but I can't find an option or correct syntax.
My survey is also connected to a Collector map via a pop-up link.  This text is pulled into the survey via the link.  I have tried using an attribute expression to get the character I need.  ex:"Left($feature.ATTRIBUTE1, 3)"  This does pull the characters, however, I cannot seem to pass the expression results to Survey123.
An example link for collector to survey for what I've tried:
arcgis-survey123://?itemID=4abe30290a954139bc5f2d7eirnfq9b5&field:Question2={expression/expr1}
Jing_Sun
Hi Aaron,
I think the function you are looking for is substr().
More information can be found on the Formulas page.
Formulas—Survey123 for ArcGIS | Documentation
Cheers,
Sun
Jing_Sun
Hi Aaron,
Cheers,
Sun
AaronFisher3
Thank-you for this!
