Unable to update web survey when publishing from ArcGIS Survey123 Connect
329
02-14-2024 12:43 PM
JoseBarrios1
Hello everyone,
I am having problems updating surveys from Connect. The changes are not published. It publish from connect with no errors but the changes are not reflected on the web form. I try with several surveys and all got the same behaviour. The esri support document (https://support.esri.com/en-us/knowledge-base/problem-unable-to-update-and-publish-surveys-from-arcg...) point the cause to the items been moved to another folder in ArcGIS Online but the items were never moved. I did check the ownerFolder item id and it keep changing everytime that update the form content. Any suggestion???  Connect Version 3.19.104
JB
JoseBarrios1
Update: For some reason adding a new question(text) did push the updates to the web form. Changing juts the label content  and calculations did not work for me!
DougBrowning
Did you make sure this is still on when Publishing?
JoseBarrios1
Hello Doug,
Yes. it is on. I just publish a very simple form to test and it works. I try several of my other forms and don't work. Not sure what it is going on!
JoseBarrios1
