When trying publish a survey from web, we get the following error:
We have gone through the schema to make sure there are no duplicate field names, tried recreating the survey, save as, tried publishing from different computers... I made a test survey by just dragging and dropping about 15 questions (without changing default values) and published just fine, so we are able to publish surveys.
We searched the error and there was not a lot of responses, but the ones we did see seemed to have more information after the "message:"
We are using an enterprise portal environment.
Any help is appreciated in advance!
Ryan O'Quinn
