Survey123 Lookup PullData
1330
03-03-2021 07:02 AM
jaykapalczynski
Honored Contributor
Using survey123 I can add a table to be used as a lookup table.  If this table changes it requires me to republish the Survey123 application every time that list changes...and on my side it does change daily.  This is very hard to manage
OFFLINE
Is there an easier way to update this lookup table than republishing the whole Survey123 each time?  Which requires the user to download the form each day.
Where is this lookup table stored on the actual device?  Phone, Laptop etc
Can I update this table separate from updating the entire form?
ONLINE
Is there a way to reference a table from a rest endpoint if we are working online, to be used as the lookup table?
DougBrowning
MVP Esteemed Contributor
Yes but some of this is early adopter still.
See here from yesterday.   https://community.esri.com/t5/arcgis-survey123-blog/what-s-new-in-arcgis-survey123-february-2021/ba-...
