TypeError Cannot read properties of null (reading current version
23298
16
10-04-2021 10:39 AM
RafaelCelaya
Hello my name is Ralph has anyone seen this error before? It happens when I enter a filter. An error occurred while applying the filter. TypeError: Cannot read properties of null (reading 'currentVersion')
ZacharySutherby
Hello @RafaelCelaya
If you are applying a filter to a field in a repeat we have an issue logged regarding this error. We are working on a fix for the issue, in the meantime please feel free to reach out to Esri Technical Support and have them attach you to BUG-000143323 to track progress on the issue.
Thank you,
Zach
ZacharySutherby
Hello @RafaelCelaya
Thank you,
Zach
RafaelCelaya
Thank you Sir, I will reach out to Eris Technical Support.
by Anonymous User
Not applicable
I am also having this issue when trying to filter by related data within Survey123. Does anyone know if there has been any update on this?
FredMitchell
I am also getting this error trying to filter data in Survey123 but not in a repeat. TypeError: Cannot read properties of null (reading 'currentVersion'). @ZacharySutherby are there any updates on this?
MarkGambordella
just wondering if you found a workaround.  I am trying to pull out only the First Attachment from a survey123 form to show in a popup and get the same error
ZacharySutherby
Hello @RafaelCelaya @Anonymous User @FredMitchell
We have a fix for this issue in plan for our 3.13 October update, the fix is currently on our survey123beta website. If we may ask, please test on https://survey1232beta.arcgis.com and let us know if the behavior is still present there.
Thank you,
Zach
by Anonymous User
Not applicable
I cannot access this webpage... it gives the response :"Hmmm… can't reach this page".
FredMitchell
There's a typo in the link from Zach...remove the 2 before beta and it will work!
by Anonymous User
Not applicable
It works great!
