Trying to use data from a different layer to auto locate people in survey123 web designer
1138
06-29-2023 07:10 PM
AndrewCastilloTBSL
I have a survey in Survey123 Web Designer that has a drop-down input of names that were extracted from a different survey layer.
I have configured other inputs to auto-populate based on that same survey layer but I'm trying to get the Map input to auto-populate where when I select a patient it automatically shows the location based on that patients associated location which was inputted from a previous survey.
I'm trying to do that, but it doesn't seem to be working. and I'm not sure where to find it in the maps calculation section
When I choose select output filed all I see is string data, How can I get it to choose location to fill from that previous layer?
IsmaelChivite
Esri Notable Contributor
Sorry, Not supported for now in the designer. You need Connect for that. More details here: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-creating-a-geolist...   @AndrewCastilloTBSL
AndrewCastilloTBSL
Ok I see, thanks for answering.
