Hi, after the last update received in Survey123 connect (3.14.256), several Survey form's item details are not accessible in our organization. Please see the screenshot below.
I get that error in Chrome:
But I get CORS in Firefox:
You are getting it on the same group ID we are - an esri created group for ArcGIS Online vector basemaps. Makes me think that ESRI's servers hosting those basemaps are the source of the CORS problems, not our portals.
Seems like that may be the legacy vector basemaps as well, although I don't think it's due to anything we have configured.
Update: The failing request also fails with cURL, which would not be affected by CORS.
I am having an issue with the update as well, on iPhone and iPads. I can load my surveys but the data is not pulling into inboxed forms.
@JamesTedrick @IsmaelChivite Any updates on a fix here? or timeline on one?
Thanks all. We are investigating this issue. We are going to roll back momentarily to 3.13 until we can test a fix with 3.14.
Still having issues with report generation across the board after the roll back.
Thanks for the info, but we are unable to generate reports even after the rollback. This is a big operational problem for our agency and we really need to be able to give everyone a timeline for when it will be working again. Is there any update?
Agreed -- this is a really, really, really big deal for us. We have a public-facing application that fails if a report can't be generated.
Is there any update? Our service and clients are being heavily affected.
how did upgrade the system without a proper test?
