The media in the survey form fails to display in the Survey123 web app after the form is published from ArcGIS Survey123 Connect
1625
19
05-06-2025 10:50 AM
YasnaiaMassie
Please see attached doc for better understanding.
I using ArcGIS Enterprise 10.9 for publishing survey, and Survey123 Connect 3.22.
And all my images/file extensions  are lower case.
Thank you
DougBrowning
MVP Esteemed Contributor
Any spaces in the name?
YasnaiaMassie
It had before but I renamed it. No spaces in the name now
DougBrowning
You said they are all lowercase but these are not.  It can be any case but it is case sensitive.
YasnaiaMassie
Sorry for the misunderstanding. I meant the file extension in lower case ".png"
The image cases are matching- the excel file in the survey with  the name in the "image folder"
DougBrowning
Hmm almost seems more like its the filter.  Are you using selected() vs = for the filter?  Do the cases all match there?  You are checking against name column not label?  Are the choices in the form or csv?
Neal_t_k
Along Doug's line, check the capitalization for this list and ensure you are using the names and not labels.
YasnaiaMassie
Here is what I have.  See image
Should I change the name of the labels to be different from "mapsource"?
Neal_t_k
Are you getting an error message or are they just not showing?
Are you seeing this: https://community.esri.com/t5/arcgis-survey123-questions/survey-123-form-error-initializing-form-err...
if so, you can put "?version=3.21" after your url on for the webform and it may bypass the error code.
Also are you using the minimal appearance for you select_one question with the images?  If so try taking that appearance off and see what happens.
YasnaiaMassie
We are in the right path.
I did cross out "minimal appearance", and I can see the image but I can't click it to enlarge it.
And I did save to 3.18. See image.
Where exactly "?version=3.21" goes?
https://<host>:<port>/arcgis/sharing/rest/content/items/21a6c530b31a4523bdff7gg94c9c5d9a
You have been so helpful.
Thank u
