Survey123 select_one filter by field
1045
10-18-2023 11:02 AM
ChristopherMask
Hello Community,
I want to filter select_one_from_file ResourceRates.csv. to the current year, so the appropriate rate can be returned form the linked csv.
Purpose to use the field ${CalendarYear} to filter and only return rates where ${CalendarYear} = ${YearOfRate}.
Is the possible using autocomplete search?
Christopher
ChristopherMask
set appearance to autocomplete
added this to choice_filter  selected(${CalendarYear},YearOfRate)
This worked and now rates for each year can be added to csv and the survey will filter out based on the year.
ChristopherMask
Can I do something like this?
autocomplete search('ResouceRates', 'matches','YearOfRate', ${CalendarYear})
ChristopherMask
