In case this is different from the ArcGISRequestError, I will make a separate post.
Presently, my reports are just timing out without an error message. This started ~3 hours ago. No reports are generating at this time (no error message).
(This is from Power Automate. The automation timed out after ~30 minutes)
Hi @abureaux,
This behavior is consistent with how the service disruption earlier today was impacting the report API. The disruption status has been set to resolved and we are seeing export functionality returned to normal on our end. Are you still seeing issues with exporting reports?
-Barbara
Hi @abureaux,
-Barbara
@BarbaraWebster1 We're still seeing some issues with report generation, particularly with getting stuck at the "Packaging" stage. This one has been going for 10+ minutes.
And the associated error message
Hi @RobBlash,
Thanks for reporting this. Can you provide the following information?
-Barbara
Hi Barbara,
FYI I have a support ticket open (03366594) but due to workload I have not been able to get on a call w/ them.
@BarbaraWebster1 we are still experiencing the issue this morning.
@RobBlash Thanks for the information and update. I've sent a direct message requesting some additional information.
The fix to the issue "An error occurred when packaging due to timeout." is available on the Survey123 website, you should be able to print hundreds of reports in one job now.
Please let us know if you still observe any issue during your workflow. Thank you again for your feedback.
