Survey123 Connect, Constraint, Answer does not equal to list from file
1517
07-22-2024 09:16 AM
SophieSanders
Hello,
Does anyone know how to apply a constraint so that answer cannot be an ID pulled from a file.csv list,
like the opposite of select one from file, e.g. constraint cannot be from file list,
Many thanks,
2 Solutions
abureaux
MVP Frequent Contributor
A little more info would be helpful. Do you mean something like...
  • You have an external list that you don't want user to select from? E.g., Text_Box_1 != list.csv
  • You have a repeat with a dropdown that users can select from and you don't want them adding duplicates to the repeat?
SophieSanders
Hi abureaux,
Your first suggest is exactly what I needed, I hadn't been including the text_box_name
I've now used this in the constraints field and it worked!, thank you for your help ${Text_box_name} !=list.csv
abureaux
SophieSanders
Hi abureaux,
