Survey123 Collaboration Settings Not Working properly
713
04-11-2024 05:24 PM
Hollreiser_Kelly
I am having an issue with the Share Results Collaboration function in Survey123. Members of a shared group are unable to view the results of the survey in the data view on the Web.
These are the settings I have selected under the Share Results Tab in Collaborate for the survey:
Who can view results of this survey? I have a specific Group within my Organization selected
What data can viewers see? All records in this survey
What can viewers do? View and export data
Notes: The survey was edited and published in Survey123 Connect.
Is anyone else experiencing this? Not sure why there is an issue. Any advice would be appreciated.
Thank you,
Kelly
HannesVogel
Hi @Hollreiser_Kelly , are you using ArcGIS Enterprise and did you create the survey with an existing referenced feature-service? If yes @ZachBodenner  and I have the same problem:
https://community.esri.com/t5/arcgis-survey123-questions/user-can-t-see-shared-survey-in-website-ent...
