Summary Reports fail to generate when >20 records selected
1529
07-08-2021 05:46 AM
erica_poisson
Survey123 consistently fails when generating a summary reports containing >20 records. For one of my surveys, I created a quarterly reporting template for my end users. They should be able to select all records for a 3 month period and create a summary report with a few clicks of a button. Instead, they get consistent failures and I need to go in and generate reports for them, and then compile them using Excel. This defeats the purpose of a summary report template.
This is extremely frustrating! Instead of generating 1 summary report, I have to generate 1 per batch of ~20 records and then use Excel to add all of the values together.
For example, this quarter (April 1 to June 30) has 391 records - imagine generating a summary report for every 20 of those!
The error code flip flops between a generic "we couldn't generate the report" to something more specific with syntax. The odd thing about the syntax portion is that as long as I don't pass the 20 record threshold, the report template works fine. I also receive no errors when uploading the report template.
I have been suffering through this for months now - is there any end in sight?
@IsmaelChivite
Thank you,
Erica
Ruth_JiatengXu
Hi @erica_poisson
We have been working on enhancing the performance of the report service, and our new build may solve your issue. Zhifang will contact you with the details.
Ruth
Ruth_JiatengXu
Hi @erica_poisson
Ruth
erica_poisson
Hi @Ruth_JiatengXu
Thank you! I just tested the beta build and replied to Zhifang's email. It worked perfectly! I appreciate this very much.
I look forward to this beta build getting released for public use.
Erica
Erica
