Sharing survey results with every one
461
08-18-2025 08:26 AM
ax19th
Hi everyone,
i have a problem to share results survey with "everyone"
The link generated to the survey's results shows juste data in table/shart/and maps format with no link or way to download them in different formats (CSV, KML...etc)
Is there any solution to this
The survey is shared publicly for view and export in the sharing tab
Thank you!
DougBrowning
Flip to the data tab in https://survey123.arcgis.com/ and there are Export options.  You can even make PDF reports.
ChrisBoland
There should be a corresponding Hosted Feature Layer in your ArcGIS Online organizational account by the name of [SurveyName]_results.  If you want "everyone" to be able to download or view the data, set this hosted feature layer's access level to "Everyone" and share out the link to that dataset.
