"if and" statements
950
11-26-2021 08:32 AM
Direción_Metropolitana_deDesar
Hi everyone, I'm new using survey123 connect and I Want to know What  is wrong with this:
Im trying to use "if and" statemtents, but when I save an error appears.
Im using
if(${IC}<1 and {AIVA}<120, 0.17, "OTRO VALOR") and also I tried if((${IC}<1, 0.17) and ({AIVA}<120 ,0.17), 0.17, "OTRO VALOR"), but didnt work.
Thank You
IsmaelChivite
Esri Notable Contributor
Hi. You are missing $ in front of {AIVA}. The correct expression is: if(${IC}<1 and ${AIVA}<120, 0.17, "OTRO VALOR")
A few additional suggestions for the form design:
  • In row 11, you have a decimal question with a calculation that outputs a string ("OTRO VALOR"). This is not good. You cannot store text in a decimal question.
  • Rows 3 to 10 all share the same expression in the relevant column. This is not an issue in your form because it is small, but generally speaking you should consider grouping your questions and apply a relevant statement to the group, rather than every question. This will make your survey more efficient.
Hope it helps.
IsmaelChivite
Hope it helps.
