Question about faster submitting in the Survey 123 field app
890
10-27-2020 02:25 AM
JurgenRotteveel
I made a Survey in Survey 123 Connect and I was wondering if it is possible to automatically save the form and open a new empty form after clicking/pressing on the check mark in the right bottom of the screen.
I want to use the survey for counting birds so I have to submit the data fast.
Best regards,
Jurgen Rotteveel
by Anonymous User
Not applicable
Hi Jurgen,
No, this is not currently possible. If you want to see this as a new feature or enhancement in the future, I suggest you create a new idea on the ArcGIS Survey123 Ideas website.
Alternatively, have you considered using a repeat (related table) in your survey. The parent layer could contain just your date/day, location and user information. And then the related table could include information about the birds sighted, and you add a new record for each bird seen. This would allow you to add new records quickly in the same survey with details without needing to create an entire new survey.
Regards,
Phil.
JurgenRotteveel
Hi Philip,
Thanks for your answer, the repeat function works great!
Best regards
Jurgen Rotteveel
