Pulling data values to repeated group
3022
03-25-2021 11:56 AM
Ali_Hussein_Awad
Hello, can i pull data values from a .CSV file to a repeated group?
if yes, what is the best way?
thank you.
IsmaelChivite
Esri Notable Contributor
I am not sure I fully understand your question.
If you want to calculate a question within a repeat using pulldata(), the answer is yes. There is no difference between using pulldata() in or out of a repeat.
If you want to populate entire repeat records from a pulldata() function, the answer is no. A repeat group can only be populated with records through the Inbox. You cannot create a new record in a repeat using an XLSForm expression.
IsmaelChivite
Ali_Hussein_Awad
Okk thank you @IsmaelChivite !
I want to calculate a question within a repeat using pulldata().
AnaDeniston
Hi @IsmaelChivite
Is there a way to work around filling up entire repeat records? Perhaps using Java?
Thank you,
Ana
IsmaelChivite
Not that I am aware of. Technically, you cannot calculate a value on a record that does not exist. That is, you can't have the survey automatically add a new record to a repeat.   If you have an existing record in a repeat, you can prepoulate values using the calculation column, but not add the new row. Makes sense?
