pulldata @layer for rasters
119
yesterday
AMur
New Member
In Survey123 I am trying to query a DEM raster layer from map lick or coordinates with pulldata @layer but cannot find how to read the stretch.pixel value. Under the layer's service page, Fields is None so not sure what to put in for "attributes"
ChristopherCounsell
MVP Regular Contributor
Survey123 pulldata(@"layer" is for feature layers, feature tables or query enabled map services.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#ESRI_SECTION1_BB97985...
You may be able to achieve this with JavaScript e.g. here's a starting point:
https://community.esri.com/t5/arcgis-survey123-questions/survey123-javascript-extension-identify-pix...
Neal_t_k
How big is your area of interest and what level of detail do you need the results?  I know DEMs are large when converted to vector even larger, but if you had a small are of interest and could generalize the DEM a bit, you could convert it to a polygon layer and the use the point in polygon pulldata method.
