pulldata @layer for rasters
1226
08-20-2025 07:19 PM
AMur
In Survey123 I am trying to query a DEM raster layer from map lick or coordinates with pulldata @layer but cannot find how to read the stretch.pixel value. Under the layer's service page, Fields is None so not sure what to put in for "attributes"
ChristopherCounsell
MVP Frequent Contributor
Survey123 pulldata(@"layer" is for feature layers, feature tables or query enabled map services.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#ESRI_SECTION1_BB97985...
You may be able to achieve this with JavaScript e.g. here's a starting point:
https://community.esri.com/t5/arcgis-survey123-questions/survey123-javascript-extension-identify-pix...
AMur
I have tried to use javascript to perform the action but am running in to issues with the returned json. I am connected through an Enterprise account but if I use the parent url the below script returns the error 'Token Required'. The error in Survey123 is always the same. I can use a child layer and paste the identify url in a browser but it will only return the layer attributes, never the value of the coordinates.
This script creates the following url (I have removed the url and lat/lon info)
<url>/identify?geometry=%7B"x"%3A<lon>%2C"y"%3A<lat>%2C"spatialReference"%3A%7B"wkid"%3A4326%7D%7D&geometryType=esriGeometryPoint&returnGeometry=false&returnCatalogItems=false&f=json
// rasterPixelValue.js
// Call from XLSForm: pulldata("@javascript", "rasterPixelValue.js", "getRasterValue", imageServiceUrl, longitude, latitude)
function getRasterValue(imageServiceUrl, longitude, latitude) {
// Validate inputs
if (!imageServiceUrl || !longitude || !latitude) {
return "Error: Missing required parameters (imageServiceUrl, longitude, latitude)";
// Convert coordinates to numbers
const lon = parseFloat(longitude);
const lat = parseFloat(latitude);
if (isNaN(lon) || isNaN(lat)) {
return "Error: Invalid coordinates";
try {
// Build the identify request URL
const identifyUrl = imageServiceUrl.endsWith('/')
? imageServiceUrl + 'identify'
: imageServiceUrl + '/identify';
// Create the geometry parameter
const geometry = JSON.stringify({
x: lon,
y: lat,
spatialReference: { wkid: 4326 }
// Build request parameters manually
const params = [
'geometry=' + encodeURIComponent(geometry),
'geometryType=esriGeometryPoint',
'returnGeometry=false',
'returnCatalogItems=false',
'f=json'
const requestUrl = identifyUrl + '?' + params.join('&');
// Make synchronous request (required for Survey123 pulldata functions)
const xhr = new XMLHttpRequest();
xhr.open('GET', requestUrl, false); // false = synchronous
xhr.withCredentials = true;
xhr.send();
if (xhr.status === 200) {
const response = JSON.parse(xhr.responseText);
// Check for errors in response
if (response.error) {
return "Error: " + response.error.message + " " +requestUrl;
// Extract pixel value
let pixelValue = null;
if (response.value !== undefined && response.value !== null) {
pixelValue = response.value;
} else if (response.values && response.values.length > 0) {
// For multi-band rasters, return first band or comma-separated values
pixelValue = response.values.length === 1 ? response.values[0] : response.values.join(',');
} else if (response.properties && Object.keys(response.properties).length > 0) {
// Sometimes pixel data is in properties
const keys = Object.keys(response.properties);
pixelValue = response.properties[keys[0]]; // Return first property value
// Return the pixel value or "No Data" if null/undefined
return pixelValue !== null && pixelValue !== undefined ? pixelValue.toString() : "No Data";
} else {
return "Error: HTTP " + xhr.status + " - Unable to query image service";
} catch (error) {
return "Error: " + error.message;
Neal_t_k
MVP Regular Contributor
How big is your area of interest and what level of detail do you need the results?  I know DEMs are large when converted to vector even larger, but if you had a small are of interest and could generalize the DEM a bit, you could convert it to a polygon layer and the use the point in polygon pulldata method.
