I used Survey 123 Connect Version 3.18.123 to create a survey. When I view the feature layer, I have the main table and another table that is part of the layer (related I think) for employees which is a repeat ( I am new to this so I apologize if I am not describing this well).
I have generated a summary report. Everything works, but one of my fields. I am trying to pull records from the employee table based on information from the main table. No matter what I try I receive an error.
Basically, if an employee (or two or three) attend a specific event (the events are in the main table). I want to be able to "query" the event type(main table), order by event date(main table), and pull the employees from the employee table.
I have attached my Excel for the Survey 123 Connect, the Summary Report, and a screenshot of my layer in Portal (layer plus the employee table) below. Please look at the Business VSQG section of the report as I have not formatted the rest completely yet. It is the "employee" column (highlighted) that I cannot get to work.
It produces an error: Error: An error occurred when checking the report template. Failed to parse ${employee_name} since employee_name cannot be found in the current parsing scope.
The error makes sense to me;however, I do not know the correct syntax. I've been spinning my wheels for two days now. I appreciate any guidance as I am in a time crunch.
