Publish Survey with Submission URL Error
2323
7
06-16-2020 08:19 AM
GISManager4
The custom feature service submission url i snot compatible with this survey. (Fields not found in the feature service.)
Trying to publish a survey that will write records to a related table. I have successfully completed this before. I am following instructions found: How To: Create Survey123 for ArcGIS surveys that connect to non-federated ArcGIS Server services
Feature service and table: https://services1.arcgis.com/a0b6GuyTJaCYvfET/arcgis/rest/services/Stream_Road_Crossing/FeatureServe...
DougBrowning
MVP Esteemed Contributor
It could be the field Date.  That is a reserved word and has gotten me before with strange errors.  Look at the types tab for a list of all reserved words.
I also see images in there.  Do you have attachments turned on in the service?
Hope that helps.
GISManager4
Yes attachments are enabled for table. Will look at DATE field. thanks
GISManager4
DATE does not appear in Reserved Keywords
DougBrowning
I see it in my form.  Is yours old?
GISManager4
Didn't scroll far enough down.
GISManager4
I changed the DATE name field, but still get the error. I had to battle a few other errors before returning to this error; field length too short. So I changed all the text field lengths to 255.
DougBrowning
Correct 123 now defaults to 255.  You can change this using the bind:esri Field Length column to match your service.
