Manually add Lat and Long to survey and create point on map in survey123 connect
1299
02-27-2023 12:36 PM
anonymous55
Hello
I looking for a way users can add Latitude and Longitude in survey and then map show the location? is it any way users can manually type lat and long to appear on map (geopoint)
IsmaelChivite
Esri Notable Contributor
If you do not want to store the geopoint in the feature layer, set the bind::esri:fieldType column to null.
Remember you can also use your own web map or mobile map package for your geopoint question as described here.
IsmaelChivite
