Making the non-form background a different color
2132
11-21-2018 01:41 PM
DavidBuehler
How do I make a Survey123 form's non-form background when open in a web browser a different color?  In the attached image is what I get when open it normally in a web browser is on the left.  I would like to do what is on the right.
non-form background color change
JohnathanHasthorpe
Hi David - this background can only be changed for forms that were created in the web designer. I assume this form was created using Connect?
JohnathanHasthorpe
DavidBuehler
Johnathan,
That is disappointing news.  You would be correct, I indeed use Connect.  You can customize pretty much everything in Connect. Why is this functionality not available in Connect?
MarilyPaipeti
Hi David Buehler,
I have just had the same question and by doing some research in the forum I found a way that works fine for the web forms. To accomplish something like this, open the <Surveyname>.info file in the survey's folder and paste the the code shown below just before the last "}":
"webformInfo": {
        "themes": [
                "isEnabled": true,
                "webpage": {
                    "backgroundColor": "#CACACA"
This code works for v3.1 and above. You can find more info at this thread:
Viewing Survey123 form on Web-Pale blue "wrapper"?
Since your question is a bit old, I hope that you have already found the solution, but I thought that maybe it will help others too.
Regards,
Marily
JamesTedrick
Esri Esteemed Contributor
Hi Marily,
Just to note, you can now set this style setting via the Survey123 website for all surveys - enter the Design tab and open the 'Appearance' panel.
JimPugh2
Using Connect, you can set the background color of a group by using backgroundColor property in the body::esri::style column (on the begin group line). The backgroundColor color is specified using either the hex color code or the standard HTML color name, e.g. backgroundColor="#eeeeee" (light gray) or backgroundColor="MistyRose"
