Internal server-side error - Reports
25030
51
10-10-2023 08:12 AM
LucianoSantoni5
Good morning, I would like to know if anyone is experiencing the same problem. Suddenly our Survey123 reports stopped generating with the following error: Internal server-side error.
There is a similar post from 2020, it seems to have been fixed with a patch. (https://community.esri.com/t5/arcgis-survey123-questions/internal-server-side-error/m-p/791415)
Is anyone having the same problem?
RobertAnderson3
MVP Regular Contributor
Thank you for the update Zach!
I just tested and it seems to resolve the Data page loading issues I was having as well! (even the issue with the form view I've been having for ages because of hosted tables and null geopoints seems resolved)
RobertAnderson3
Oh I should clarify for myself, I am NOT using Enterprise, simply ArcGIS Online.
lmendez_sp
Hi Zach,
For some reason, Survey123 Beta is not displaying data in my surveys, neither in one portal nor other. In both Portals, there are the same issues described in this post (report generation failing since the beginning of this week, so that's why I wanted to test the fix in Survey123 Beta website).
One portal is 10.8.1 and the other one is 10.9.1.
Best wishes,
-Luis
ZacharySutherby
Hey @lmendez_sp
Do you see the same behavior in the production Survey123 website? It looks like the Survey123 website isn't able to find the feature services that the surveys point to. Does your ArcGIS Data Store validate successfully in ArcGIS Server Manager / Are you able to create a sample hosted feature service in your Portal?
If you capture the network traffic while you load the My surveys page there should be a handful of relatedItems requests. What is the response for one of those relatedItems requests?
Thank you,
Zach
lmendez_sp
Hi @ZacharySutherby ,
I'm sending you 2 .txt files representing console messages and a relatedItem request, respectively. There are also some screenshots in case you want to check out some of the messages that appeared at "My surveys page" reloaded page.
This only occurs on Survey123 Beta website for both Portals: 10.8.1 and 10.9.1.
I hope this can be helpful.
Thank you,
-Luis
lmendez_sp
P.D. for 10.8.1:
  • ArcGIS Data Store Validation: successful
  • Sample hosted feature service creation in Portal: succesful
For 10.9.1:
  • ArcGIS Data Store validation: succesful, except for Tile Cache Data Store (attachment is down below)
-Luis
ZacharySutherby
Hello @lmendez_sp
Based on the network_messages.png it looks like your organization has restricted access to the ArcGIS Server. The production Survey123 site has likely been added as a trusted site but the Survey123beta site likely has not which is causing the CORS errors. The hotfix is planned to be released tomorrow so the fix will be on the production Survey123 site at that time.
Thank you,
Zach
HarmondSantos1
Thanks for the update Zach! I've tested exporting on the beta website and works very well!
AmandaNunley1
We have been experiencing this issue as well, since last Tuesday. I just tested out the fix on the beta site & can verify that it resolved our problem. Looking forward to when this rolls out tomorrow!!
hherrmann_coj
Do we have a time frame for the fix being applied today?
