Filtering integers broken after October 25 2022 update?
6435
19
10-26-2022 05:57 AM
RobBlash
I'm getting an error when filtering on integer fields this morning. This was working fine prior to the update yesterday. Anyone else? I'm going to submit a support ticket but also posting here to see who else is having trouble.
2 Solutions
ZhifangWang
Hi @RobBlash @AndyMcClary @TracySchloss ,
I can reproduce the issue on the latest Survey123 website, sorry for the inconvenience.
We are looking into the details and will evaluate a hotfix to address this issue.
Zhifang
ZhifangWang
Hi ALL,
The fix to this issue is available on the Survey123 website https://survey123.arcgis.com now.
Thank you ALL again for the feedback and tests on the fix.
Best,
AndyMcClary
I'm seeing the same issue. Seems to be limited to integer fields but I haven't tested extensively.
RobBlash
After some work attempts it seems like any numeric character in the filtering will throw the error. I have a premium support ticket in already, will report back.
TracySchloss
Honored Contributor
We're seeing the same issue in all our surveys, and we use this functionality a lot.  Esri please fix this!
RobBlash
Support has confirmed they can reproduce the issue. I'll update once I get more info.
ZhifangWang
Zhifang
JeffLegato1
We are experiencing the same issue.  I found a temporary workaround for our issue by setting the filter in the link to be
filter=(1.OBJECTID%20isBetween%20{OBJECTID|%20and%20{OBJECTID})
DavidMichaels
We are experience this issue as well but including text fields with out integers
RobBlash
@ZhifangWang is there any timeline on a potential hot fix?
GIS_Fox
We are still experiencing the same error with both integers and other characters as of this morning 10-28-22. We've been able to get workarounds done with other filter tools or manually selecting items but field users are in need of this function.
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
