Feature Reports: Update Field From Previous Instance of Survey?
3178
21
04-29-2025 09:34 AM
JW_TT
I've created a feature report for surveying the status of items in a factory. The items are surveyed once a month. The Survey123 survey looks great. The feature report template puts out a pdf that looks great. One of the fields on the survey is "Inspection Date" for the date of the survey. There is also a field "Previous Inspection Date." When the survey is first carried out, "Previous Inspection Date" will be blank. After a month, on the date of the second survey, I'd like the "Previous Inspection Date" field to be populated with the date of the first survey. Every month when the surveyor surveys a particular item, the date of the previous survey of that item is automatically populated.
I've tried "pullData" syntax in a variety of forms, but none seem to work. Am I just missing something? This must be a common process. I'm in a fairly strict corporate environment. Any suggestions, links, etc., would be great.
Thanks!
Tags (1)
Neal_t_k
I changed everything back to your variables, but the attached does pull the most recent date when I hook it up to one of my feature layers???  If  not it may have something to do with your feature layer settings, have you checked the share setting in Survey123 site.
I am not sure if these setting would effect it but worth a shot
Neal_t_k
How is the survey form setup? Are surveyors collecting a new record each time they perform an inspection or are you using a repeat function and they are opening an existing form and adding the new information in a repeat?
If it is a new survey form each visit, you will probably need to using the pulldata function to pull the previous date from your data into your form first before you try putting in the report.
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-pulldata-quot-laye...
https://community.esri.com/t5/arcgis-survey123-questions/survey-connect-123-to-pull-data-function-an...
If you are collecting dates within a repeat, there is specific format for calling data from within a repeat.
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereport-repeats.htm
Some more information would be helpful on how your form is setup.
JW_TT
Thank you very much for the response.
The surveyors are collecting a new record each time. I've attached my XLS Form. I thought that my syntax is correct. I've collected a couple of surveys of the same container (NB-1) and am under the impression that when I select container "NB-1" that the "Prior Monthly Inspection Date" text field on a new survey on my phone, that data should be pulled into that field. But that's not happening.
I know just enough to be dangerous, so thank you again for the help!
Neal_t_k
Try something like this:
You may need to adjust the where clause to ensure you are get the most recent date.
https://community.esri.com/t5/arcgis-survey123-questions/is-it-possible-within-a-survey123-smart-for...
JW_TT
Thank you for that. I've deleted all previous records in the feature class. I've republished the survey. I've created one new inspection of NB-1 so "most recent date" should make no difference.
And... nada. I start a new survey of NB-1 and the "Prior Inspection Date" field remains blank.
Any thoughts? I'm stuck.
DougBrowning
MVP Esteemed Contributor
pulldata tends to fire first before co_fa has a value.  Try adding a relevant so it does not fire until co_fa is filled out.  You can also try calculationmode=always
JW_TT
Can I talk you into putting that into the XLS so I can see it that way? I'm a visual learner and need to actually see it in place to make it connect.
DougBrowning
Just add this to the relevant for pulldata line  string-length(${co_fa}) > 0
JW_TT
Hmm. That just made the entire prior inspection field disappear from the survey. That's one way of dealing with it, but unlikely to make my boss happy. 😑
I'm not sure what to try next, everything seems in order.
JW_TT
Thank you for this!!
