Survey Connect 123 to pull data function and get max value
1467
06-06-2024 06:01 AM
Highway28WaterAssociation
I am trying to return the max meter reading in an existing Feature Class. Here is the pull function I am attempting to use.
pulldata("@layer", "getValue", "attributes.Current_Reading", ${public_layer_url2}, max(${where1}))
however nothing returns :   the where1 returns the unique id for that meter using the barcode function.
Any help would be appreciated
DougBrowning
MVP Esteemed Contributor
Been posted a few times that pulldata does not like having functions inside the call and they do not run.
Move max(${where1}) to its own field then use that field in the call.
Hope that does it
