Error transferring <https://survey123..> - server replied: Payload Too Large
909
10-05-2022 04:17 AM
MarceloEdy_Peinado
Hello,
We have a issue when publish a form using survey123 connect for ArcGIS.
After implement a long list values in choices tab in form using XLSForm, the form shows error when we trying to publish.
Anybody had the same problem and could help us?
Note: The choice list tab growed up to 34,564 rows.
DougBrowning
MVP Esteemed Contributor
DougBrowning
You should use a standalone CSV for a list that large.
See https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-external-choice/ba...
Hope that helps
MarceloEdy_Peinado
Thanks Doug!
Your suggestion solved my problem!
Best regards
