Empty Drop Downs
687
10-08-2024 10:29 AM
RichardOHearn
I created a Survey123 on the web (not using Survey123 Connect) and when I try to use it in the field the (2) drop downs (single answer) are empty...why?
DougBrowning
MVP Esteemed Contributor
This is usually special chars in the CSV, spaces in the name of the csv, wrong case on csv file name, or using pulldata with a calc inside of it or a pulldata inside a if().
If its none of those need post the form.
RichardOHearn
What CSV?
SpatialCadet
Id suggest checking that you are saving the the CSV format is UTF-8
RichardOHearn
I'm sorry, but I don't quite understand what you're saying here...when am I exporting something?
Form A: collects vendor company names.
Form B: collects vendor personnel names.
Both are continually being edited, with new vendors and personnel being added.
The first question in Form B is: select a vendor company name (via the drop down list)  And in Survey123 designer, I have it looking for values from Form A.
But when I open this form in the field, that drop down list is empty...so I'm not saving anything as a CSV anywhere....
