Delete Responses
1133
08-24-2021 05:29 PM
GarrettRSmith
Hello
I have around 50 Survey123 responses (points) out of ~1,500 that I need to delete from my feature layer because of incorrect collection.
Is there an efficient way to do this? I cannot find a way to do it in ArcGIS Online or through the Survey123 website. They all have unique ids based on the ObjectID field and I cannot seem to find that in Survey123's website.
Thanks and have a great night
jcarlson
Is there some way of easily identifying the 50 responses in question? You can use the service's REST endpoint to delete features. You could also open the layer in ArcGIS Pro and delete the features there.
- Josh Carlson
Kendall County GIS
DougBrowning
MVP Esteemed Contributor
Do you gave access to ArcPro?  That would be the easiest way.
Another way is to use the rest end point of the service.
Go to the item page and find the service URL at the bottom right.
Then go to the page of the layer you want.  At the bottom you will see - pick delete features.
Then you can set a query or use the object ids
Hope that helps
