Can I have a sumif from a repeat?
1799
01-07-2018 07:10 AM
WaleedAl_Bukhari1
so I have a repeat that contains
select_one donationdonation_list
select_one donation_itemdonated_type
textdonated_item_size
integeritem_count
so what I need is sumif(${donated_type}='Food', item_count)
I need  the total of (item_count) when the donation type is 'food'
is that possible
DanPatterson_Retired
by Anonymous User
Not applicable
Waleed,
Currently we do not support sumif or calculations across repeats for multiple questions, only what is supported by the documentation Dan mentions above.
Phil.
TomReyes
Hello, I just wanted to check in and see if ESRI supports this now or will soon now that it has been almost 4 years since this question was originally posed.
by Anonymous User
Not applicable
If you are flexible...the next best thing?  It adds two fields but gets the results you are looking for.
