Blank rows in 'hidden' repeat
6751
11
02-07-2020 07:37 AM
ColinCampbell
I have a survey with a repeat in it that I've published from Connect but is being used as a web form.  The repeat is optional and is triggered by people selecting a particular value on the main record.  It is entirely hidden until that value is selected and this is done using a relevant statement in the 'begin repeat'.
This all looks great and works well in the web form, except for one thing.  For records where the required value to unhide the repeat isn't entered a blank record in the repeat is still created.
I've seen some posts suggesting this is expected behaviour in slightly similar circumstances but I wondered if it was also the case here - or whether there was a way to stop the blank records from being created?
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Colin,
I am not seeing the behavior you are describing with a simple form with repeat that is relevant based on a question. What types of questions are present in the repeat section?
ColinCampbell
Hi James,
The repeat becomes relevant if the user selects one of two values in a single select (I've attached the .xlsx for the survey and you can see the live form here).  The question 'Did you observe willow tit or marsh tit during your visit?' is the one that triggers the repeat (when you select 'Yes').
Just in case it helps, I've also attached a picture to show how the blank rows are appearing in the repeat.
Many thanks for your help looking into this.
Colin
JamesTedrick
Hi Colin,
I'm able to reproduce the behavior you describe with your survey.  It appears that we have an existing BUG for this behavior, BUG-000123943.  I did a little more testing and it appears related to the presence of the geopoint question in the repeat.
ColinCampbell
Hi James,
That's really helpful to know.  Thanks again for looking into it.
BrunoGomes_de_Souza
Hey James, I have the same problem.
But some repeats have no spatial information and occurs the same as described.
HNoakes
I am also seeing this with no geopoint in the repeat section. I only have two text fields.
Is there any update on the Bug?
DougBrowning
MVP Esteemed Contributor
Also checking on update since have been 20 months now.  We now have thousands of them.  Getting harder to work around.
Thanks
newwollyka
Same here. I have a household listing inside a unit listing. Empty households records are being created even if the unit is inhabitant and it is causing inconsistencies and headaches!
SébastienLétourneau
Any updates for this bug? Reported since 2018 and very annoying.
