Automatically generate unique link for different users (based on e-mail addresses)
1685
12-26-2023 07:36 AM
SanSki
Hi! 🙂
I am trying to understand how I can send out a survey to about 500 unique users (e-mail addresses), where each survey link is unique but the survey is the same. I want to be able to do it to track the response of each respondent. I know each answer has an ObjectID, but I would like to connect the survey link to one unique user (e-mail address), before the survey gets sent out.
I would like to use a list of e-mail addresses and automatically generate an unique survey link for each e-mail address.
I have looked into this, is this the way to go forward to solve my problem, or is there any other way?
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-encode-url/ba-p/89...
Thank you for any help! 🙂
Best wishes.
Tags (1)
DougBrowning
MVP Esteemed Contributor
I think you mean pass the email in to a field in the form?  That would track them.
Your URL you can pass text.
arcgis-survey123://?itemID=812a11fca7ef1194dac&field:[email protected]
I think the @ will be ok but test it.
Hope that helps
BobBooth1
Yes, you can use URL parameters to populate fields in a survey (like target user email address).
This post explains it well:
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-web-form-url/ba-p/...
You can hide that field in the survey so people don't see it.
Not sure if it is important to you to encode (hide/obfuscate) the information in the URL. If not, you can use a spreadsheet to calculate values for the URLs (Base URL column + field specification + email address value, where only email address changes).
Bob
