ArcGISRequestError: HTTP 504: UNKNOWN_ERROR for Survey123 generate report
23956
36
04-27-2021 10:52 AM
YuliaMamonova
None of the reports can be generated because of ArcGISRequestError: HTTP 504: UNKNOWN_ERROR for all of my surveys.
2 Solutions
YuliaMamonova
UPDATE: works fine on Survey123 website, no luck with Integromat yet
YuliaMamonova
UPDATE: Integromat works again too
CraigRobinson1
I am having the same problem.
YuliaMamonova
Can someone from Survey123 please let us know when this will be resolved?
This very negatively affects field operations.
IandeNeeve1
Yes, having the same issue. On multiple feature services. Please advise when it is resolved. Thank you!
YuliaMamonova
YuliaMamonova
ZhifangWang
Hi ALL,
We had an update of the Survey123 website for back-end architecture migration last night (PST). This report service issue was caused by not fully resizing the performance to the previous scale, it is fixed now. If you still observe any issues, please let us know.
Thank you again for all your feedbacks.
DionO_Reilly
We are getting the same error the last couple of days.  We connect to our Portal through the Survey123 website and run our reports.  Any suggestions would be appreciated.  Thank you
ZhifangWang
Hi @DionO_Reilly
Thanks for reaching to us.
  • Did your report run well without issue before this week?
  • When the error occurs, did the task contains a lot of record/repeat record or maps/images?
  • Can you please share a screenshot with the error message with us?
DionO_Reilly
The issue is sporadic.  One day I get the error all day the next I can print the reports.  My surveys all contain a repeat with images.
