Hi- I'm using enterprise portal 10.8.1. I am trying to display fields from related tables in the web map popups.
Been working on the Arcade expression in Web Map (Configure Popup). For some reason, in enterprise portal, the new Web Map is not available (unless my team needs to upgrade?) -- I've noticed after watching a ton of Esri videos that are all demos on AGOL, that when using Portal, not all of the right fields are plugged when using the tool as would be the case if I was using the new MapViewer on AGOL. I read a bunch of articles (many good ones!) and just about every piece of documentation on this topic, I think I've also watched every Esri video on the topic too! - 😞 but to no avail.
Right now, I have this expression below that is working, but it is displaying the name, but not the label - of the fields. In other words, it shows worker1, worker10, worker45, worker123 instead of John Doe, Mary Sue, etc.
My expression is below:
FeatureSetByRelationshipName($feature, "WA1_0v3_repeat_assignedworkers", ['assignedworkers'], false)
If anyone can help, would greatly appreciate it!
Thanks!
