An Error while generating feature report (Portal for ArcGIS)
10327
12
06-14-2020 12:34 PM
Hussam_AlJabri
I'm trying to generate a feature report for a record in the survey and it returend an error where "Error occurred when uploading result files to Portal for ArcGIS. Error in adding url file item"
- The version of ArcGIS Enterprise is 10.6.1
- No Attachment added in the Report.
- It is working fine in AGOL.
The log file mentioned the error as bellow:
Failed to add item '8a9631513bcd4ff7b7d3870600288085' from URL 'https://featurereport-prod.s3.amazonaws.com/db12bdecf308466da0c809aa968e05e5/GMT%20Distribution%20Substations%20Routine%0ASmart%20Form_OID232_20200614231944.docx?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=ASIA5SCZICL5VGTZTQP4%2F20200614%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20200614T192034Z&X-Amz-Expires=900&X-Amz-Security-Token=IQoJb3JpZ2luX2VjEBwaCXVzLWVhc3QtMSJHMEUCIQCOg6yWCVurUkAvEbv73JudrqmIIzRsS61cZcO1RVDQPgIgY%2FpH4RdOI31Rzg%2FdjMo5iT%2FO%2FKp1dsXJV4zNCLZ%2BO4Uq5QEIlP%2F%2F%2F%2F%2F%2F%2F%2F%2F%2FARACGgw5MzIxOTUwNzg5MDciDP2IFSJHnOCBVu2SXyq5AdmQyGFA4WrhsdFDYJMlDbspNpMoV%2Fbzv9p5dCR1AVZ3cice8%2Fd4RgD%2BoyKKTp4a1OUqJpNakRJ9jKMrlPK0kCK4W3yhgSlkLdqp2Ii6PLVuMwDncPxaTZisr2iK7LweRyyYZAtE4D4Hrav%2BnqiK1Q%2FN5x%2BMhywsCFoD6WPUh1c%2B4%2FkDKkH%2FYbPQmDUBhGQECZSXrd79maeelfPd8XfAumcCXRl%2FoDxHAjH440GlgebXsxPqzd0qmvI6MP%2FwmfcFOuAB12ZfqJrM5CVODuTetD8pQDtYvKx4tvQuYDrUqpowQ1wJxVuQCZipQEt8pvHeMCi2ow2JkI1y33oms%2BA7MVPXEq5Cb3ghdWHT0ldBcxfAv7qAv4DT45L4qk%2BZ7FDgZu5olQvDBdFo1qSIQJ3NeKUGmuBcRIgtJjvd9nmEWlTq2j5Bqb7%2BdjLpdfZQ5rqA%2BKQo9EWIVa%2FijhzjcCrzric6ZdE8WWg4Bf3ZDQexjahjOIc7rMhEDhbHC6FRq3k66vBhnefFg2YerGuUu%2FtI5qrqonG58DCZsFoEbIZLEBgl0gc%3D&X-Amz-Signature=ee0f64bd41c23eac0ce6b6e336b80d5bafe831815b1013430671958024941959&X-Amz-SignedHeaders=host'. Connection timed out: connect
waiting for a magic support! James TedrickIsmael Chivite
Hussam_AlJabri
Thanks Andrea, it is generating successfully! You Are Super!
AndreaV
Glad to help you.
Regards.
by Anonymous User
Not applicable
For me, adding https://arcgis-prd-survey123-use1-reports.s3.amazonaws.com to portaladmin/security/config -> allowedProxyHosts property resolved the issue.
@JamesTedrickPerhaps you could add address used for Reporting purposes to the documentation?
