AGOL User level requirements
2098
05-09-2018 06:09 AM
Lake_Worth_BeachAdmin
I am looking for documentation for survey123 and user levels in arcgis online.
System requirements—Survey123 for ArcGIS | ArcGIS
the above docs only say I need a org account. however level 1 users are not able to view any forms.
XanderBakker
Esri Esteemed Contributor
I didn't see it explicitly in the documentation or in the Frequently asked questions—Survey123 for ArcGIS | ArcGIS   (although this would be a good thing, CC dlaw-esristaff ). However when you look at https://www.esri.com/arcgis-blog/products/apps/uncategorized/your-guide-to-named-user-levels/  you will see a general comment:
What Can This New Level 1 Named Users Not Do?
  • Create any kind of content
When you fill out a survey you are creating content and for that reason you will need a level 2 named user.
XanderBakker
If your form is not shared publicly, you will need a level 2 named user to fill out the form.
ok that makes sense, any documentation on that?
XanderBakker
JamesTedrick
Thanks Xander,
While this is implied in Frequently asked questions—Survey123 for ArcGIS | ArcGIS , it can be more explicitly described; I've logged an issue to improve Survey123's documentation.
Thanks Xander and James, I have the answer I just need a hard-copy doc to show admin for budgeting purposes.
